Configures an MLD dynamic group.
| vlan_name | Specifies a VLAN name. |
| portlist | Specifies a port list. |
| IPv6_grp_ipaddress | Specifies the multicast group IPv6 address. |
N/A.
This command adds MLD groups to specific VLANs or to ports belonging to specific VLANs. After the groups are added, the expiration timer is started; this causes the groups to expire. The configuration is not saved in the configuration file. The following message is displayed on execution of this command:
INFO: This command is not saved in the configuration.
The following example configures a dynamic MLD entry so the multicast group ff02::1:1 is forwarded to VLAN marketing on ports 2:1-2:4:
configure mld snooping marketing ports 2:1-2:4 add dynamic group ff02::1:1
This command was first available in ExtremeXOS 15.3.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.1.1 Licensing Guide document.
